THANKS posted by blackomega on May 04, 2012 at 11:20 AM
Your best bet is to do a compression test and see if you are losing compression in one cylinder. Then, on the suspect cylinder, do a leak down test to figure out if it is leaking past the piston, intake or exhaust valves.
